126830 post, 7722 Temas, 5052 users
último usuario registrado:  garciagil360
« anter. próx. »
Mapa muy útil para todos
Autor Tema: Mapa muy útil para todos  (Leído 863 veces)
surtur
Andreas
« en: Vie, 11-Mar-2011, UTC 15h.30m. »
Adjunto link de un mapa que me pareció muy interesante. Necesita Flash.
http://www.avex-asso.org/dossiers/pl/espagne/index.html#espagne
Me gustaría que los que llevan mucho tiempo mirando el cielo, opinen algo sobre el mapa. Parece un poco desmotivador.
Leyenda:
White : 0-15 visible stars (without planets) according to the conditions. Very high level of light pollution and all around. Typical of big urban centre and big regional and national cities.
Magenta : 25-80 visible stars. Principles constellations began to be recognizable.
Red : 80-150 stars : constellations and others stars appears. In a telescope, Some Messier object began to be observable.
Orange : 150-250 stars in good conditions. The light pollution is present all around but some darks areas appears. Typicaly the middle suburbs.
Yellow : 250-500 stars. Strong light pollution but the Milky Way can appear in good conditions. Some Messiers among the most bright can be visible with the necked eye.
Green : 500-1000 stars : far peacefull suburbs, Milky Way many times visible but very sensitive to the atmospheric conditions. Typicaly, the glare of light pollution take a large place in the sky and reach at 40-50° of elevation.
Cyan : 1000-1500 stars. The Milky Way is visible most of the time in fonction of climatic conditions but without contrast.
Blue : 1500-2000 stars. Good sky. The Milky Way is easily visible, we began to have the sensation of a good sky, but, some source of light pollution damage the sky and in a second time the sky by reflexion at the vertical of the observer.
Night blue : 2000-3000 stars. Very good sky. The Milky Way is present and powerfull. The light glares are far away and scaterred, they don’t affect the sky quality.
Black (green by texture transparency) : more than 3000 stars. No light pollution problems revealable on the sky quality
nota admin.:
éstos mapas no son correctosy arrastran una cierta polémica entre los entendidos, ... no hay que utilizarlo
los "buenos" son los derivados del trabajo de Cinzano et al.
contaminación lumínica, mapa península ibérica, zonas observación para evitarla
My God, it's full of stars!
PoLux
24  Masculino  (TARRAGONA)
desde: nov, 2009
« RESPONDER #1 en: Vie, 11-Mar-2011, UTC 17h.31m. »
Blanco: 0-15 estrellas visibles (sin planetas) de acuerdo con las condiciones. Muy alto nivel de contaminación lumínica y alrededor de todos. Típica de gran centro urbano y cities.
Magenta grandes regionales y nacionales: 25 a 80 estrellas visibles. Constelaciones Principios comenzó a ser recognizable.
Rojo: 80-150 estrellas: las constelaciones y las estrellas otros aparece. En un telescopio, un objeto Messier comenzó a ser observable.
Naranja: 150-250 estrellas en buenas condiciones. La contaminación lumínica está presente en todo, pero parece algunas zonas sombras. Típicamente del medio suburbs.
Amarillo: 250-500 estrellas. La contaminación de luz intensa, pero la Vía Láctea puede aparecer en buenas condiciones. Algunos Messiers entre los más brillantes pueden ser visibles con la eye.
Verde: 500-1000 estrellas: ahora suburbios tranquila, Vía Láctea, muchas veces visibles, pero muy sensible a las condiciones atmosféricas. Típicamente del, el resplandor de la contaminación lumínica tener un lugar grande en el cielo y llegar a 40-50 ° de elevation.
Cyan: 1000-1500 estrellas. La Vía Láctea es visible la mayor parte del tiempo en fonction de las condiciones climáticas, pero sin contrast.
Blue: 1500-2000 estrellas. Buen cielo. La Vía Láctea es difícil de ver, empezamos a tener la sensación de un cielo bien, pero, una fuente de daños por contaminación de luz el cielo y en un segundo tiempo el cielo por la reflexión en la vertical de la observer.
Night azul: 2000-3000 estrellas. Cielo muy buena. La Vía Láctea está presente y de gran alcance. Los reflejos de luz están muy lejos y scaterred, que no afectan a la quality.
Black cielo (verde por la transparencia textura): más de 3000 estrellas. No hay problemas de contaminación lumínica revelable en la calidad del cielo angel
SW N254/1200 Dobson graduado en azimut y altura.
E-LUX 40mm. LET 25mm. UWA 15mm. SP 25,10,6mm. -1.25"-
TS WA 30mm  -2"-
Barlow 2x Celestron Ultima SV
CCD Celestron Neximage
Escapar de luz artificial
« Últ. modif.: Vie, 11-Mar-2011, UTC 17h.34m. por gabriel88 » En línea
46  Masculino
« RESPONDER #2 en: Vie, 11-Mar-2011, UTC 18h.45m. »
es que si opino,  voy a ser mas desmoralizante aún ...
deberíamos empezar a morder, morder fuerte y con veneno , ...
si no nos concienciamos de luchar nosotros,  ¿quien demonios creeis que lo hará entonces?
por cierto
Ventanaloscuro
Astrónomo
23  Masculino  Valencia
desde: jul, 2012
« RESPONDER #3 en: Mié, 11-Jul-2012, UTC 13h.59m. »
El mapa que decíais en el primer post es el que tengo yo puesto en mi blog, pero ni de coña es el bueno, los de Cinzano, actualizados serían la bomba, lo que pasa es que los que hay se han quedado atrás.
Los mapas esos se basan en población, lo cual expongo casos que me han pasado:
- Observatorio de montaña, 20 pueblos bajo esa montaña de color rojo. Población observatorio: 0. Contaminación lumínica: 0,2. Da igual lo que contaminen esos "poblados", si el observatorio no tiene a nadie, es ocuro  tomaya
- Observatorio en un pueblo: tiene 1300 habitantes, divididos en 7 aldeas. Estos se las comen, ponen la población en conjunto. Resultado: aldeas sin contaminación lumínica. Pueblo cancerígeno y nocivo. (en realidad si llega tiene 700)  tomaya
- Observatorio en Teruel. Pueblo con 1400 habitantes (censo antiguo), contaminación lumínica: 1. MALE estimada: 6,5.
¡TOOOMA YAAA!
towinta
Masculino  Norte de Madrid
desde: may, 2012
« RESPONDER #4 en: Mié, 11-Jul-2012, UTC 18h.56m. »
Ese parece exagerado. Hay uno que creo que es mas real, que se puede cargar en Google earth bastante útil para planificar buscar sítios decentes. CL_Espa_a2.kmz se llama.
Ventanaloscuro
Astrónomo
desde: jul, 2012
« RESPONDER #5 en: Mié, 11-Jul-2012, UTC 19h.00m. »
Los de Avex son exagerados y los de Cinzano generosos, quizá por la época de su realización, hace ya años.
Ahora mismo la contaminación lumínica de España estaría a mitad de camino entre la que muestran Avex y Cinzano.
46  Masculino
« RESPONDER #6 en: Jue, 12-Jul-2012, UTC 01h.22m. »
pero los que cuentan , son los de Cinzano por realización técnica y base científica
( voy a poner nota en el primer post, para que nadie se induzca a error )
Tags: mapa    Ir Arriba  subir
« anter. próx. »
 (Leído 863 veces)
casadellibro
Facebook Compartir
Página creada en 0.271 segundos con 34 queries.
