260933 post, 20377 Temas, 11726 users
[problema] adaptar accesorios SC/SCT a Maksutov Skywatcher 4" 102/1300 mak
Autor Tema: [problema] adaptar accesorios SC/SCT a Maksutov Skywatcher 4" 102/1300 mak  (Leído 6679 veces)
55
astrons: 3.29  votos: 1
pleyades89
nuria1
31  Femenino  xxxxx(albacete)
desde: jul, 2010
« del : Vie, 25-Mar-2011, UTC 15h.05m. »
Saludos .espero que en la fotos se vea la evolución del equipo, e tenido un pequeño problema
El prisma tiene una rosca sc y es un poco mas grande que la del mak ,e conseguido desmontar el adaptador del tele y lo puedo poner con rosca t. solo me gustaría saber que rosca o adaptador necesito para poder ponerlo con el soporte original directo al telescopio.
 Es un skywacher  mak 102 /1300
otros temas:
Medidas, Rosca portaocular, visual back (SC mak ETX thread, 1.25", 2", T ring)
DUDA Maksutov 127/1500 ¿acoplar Enfocador Crayford ?
* Foto0354.jpg (93.88 KB, 800x600 - visto 74 veces.)
Mucha ilusion
« respuesta #1 del : Vie, 25-Mar-2011, UTC 15h.36m. »
creo entender que necesitas ésto: ?
Mak-Cass Adapter Ring for Schmidt-Cass Accessories
    * Adapter ring lets you use popular Schmidt-Cassegrain accessories with Orion Mak-Cass telescopes.
    * Compatible with thread-on SCT accessories, e.g., visual backs, 2" SCT diagonals, camera adapters.
    * Now you can use 2" eyepieces with your Mak, or the Celestron f/6.3 Reducer/Corrector (#5120).
    * Designed with an extremely low profile to maintain the full focusing range of the telescope.
    * Precision machined from aluminum and black anodized.
Here's an accessory that will give your Maksutov-Cassegrain telescope great new versatility. Orion's "MC to SCT" Adapter Ring lets you couple a wide variety of Schmidt-Cassegrain telescope (SCT) accessories — including the popular f/6.3 Reducer/Corrector — to your Orion Mak-Cass (MC)!
The adapter ring threads into the rear cell of any Orion Maksutov-Cassegrain telescope and provides male SCT threads just like those on the rear cells of Orion, Celestron, and Meade Schmidt-Cassegrain telescopes. The threads are compatible with all thread-on SCT accessories, including visual backs, 2" SCT diagonals, and common SCT camera adapters. Now you can use 2" eyepieces with your Mak. Or reduce its long focal length and enjoy lower-power, wider-field views by threading on a Celestron f/6.3 Reducer/Corrector (#5120).
Made of anodized aluminum, the Orion adapter ring is designed with an extremely low profile to maintain the full focusing range of the telescope.
pleyades89
nuria1
desde: jul, 2010
« respuesta #2 del : Vie, 25-Mar-2011, UTC 17h.55m. »
dos dias buscando y solucion a la primera ilusionado ilusionado ilusionado gracias sebtor
tiene algun nombre esa rosca ,ya que acabo de ver que tiene otro problema de serie y tendre que cambiar todo el modulo para que sea mas largo
 Llorar Llorar Llorar
* Sin título.jpg (64.4 KB, 633x600 - visto 93 veces.)
« Últ. modif.: Vie, 25-Mar-2011, UTC 17h.56m. por pleyades89 » En línea
« respuesta #3 del : Vie, 25-Mar-2011, UTC 22h.59m. »
pero
porqué?
¿choca con algo?
¿un tubito extensor?
¿de cuánto?
igualmente si preguntas por ello en Astroshop, te recomiendo hacer dos dibujos esquemas, con lo que tienes ahora, y lo que quieres tener.
y sinó explicarlo muy bien redactado ... porqué "a distancia"  éstos asuntos de adaptadores y roscas se vuelven un poco complicados
pleyades89
nuria1
desde: jul, 2010
« respuesta #4 del : Sáb, 26-Mar-2011, UTC 15h.03m. »
me choca con el enfocador ,tenia pensado en esto ,pero no se si tengo que comprar el reductor para mak o este modelo me sirve
http://www.astroshop.eu/t-adaptors/parks-optical-schmidt-cassegrain-primaerfokus-kameraadapter/p,17459#tab_bar_1_select
« respuesta #5 del : Sáb, 26-Mar-2011, UTC 15h.55m. »
uuufff  que carito
y complicado al querer aprovechar esa diagonal para SCT
( si estuviera montado en una ecuatorial alemana, te propondría ponerle ya un flip mirror )
es que no veo mucha solución
http://www.astroshop.eu/extension-tubes/teleskop-service-2-extension-socket--optical-path-80mm/p,4576?affiliate_id=astronomo
http://www.astroshop.eu/extension-rings-%26-adaptors/televue-sct-adapter-long/p,19087?affiliate_id=astronomo
http://www.astroshop.eu/extension-rings-%26-adaptors/televue-sct-adapter-short/p,19084?affiliate_id=astronomo
tienes oculares de 2" o 1,25" ??
quizás lo mejor sería no intentar aprovechar esa diagonal de SCT
( y planetarte muy bien, que tienes, y que quieres, y que necesitas )
¿originalmente que tiene? porqué claro !  eso si que no debe "chocar"
y aprovechar para tener al menos un accesorio multi
mira éste extensor proyección ocular   2"  a roscaT
http://www.astroshop.eu/t-adaptors/teleskop-service-projection-adapter-2--with-t2-connection/p,4572?affiliate_id=astronomo
pleyades89
nuria1
desde: jul, 2010
« respuesta #6 del : Sáb, 26-Mar-2011, UTC 19h.08m. »
Acabo de encontrar una solución al problema, resulta que el prisma se desmonta en piezas y una de las roscas engancha en el porta ocular del telescopio
Gracias skywacher por poner roscas en todos lados
* Sin título.jpg (75.05 KB, 800x498 - visto 123 veces.)
« respuesta #7 del : Dom, 27-Mar-2011, UTC 03h.10m. »
¿ Skywatcher o los de TS  ?   leng
pleyades89
nuria1
desde: jul, 2010
« respuesta #8 del : Dom, 27-Mar-2011, UTC 10h.00m. »
jejejeje los 2. muchas gracias sebtor
Toni Tobaga
Masculino  Barcelona
desde: ene, 2018
« respuesta #9 del : Jue, 31-Dic-2020, UTC 22h.59m. »
Saludos, dejaré esto por aquí convencido de que a alguien le será de utilidad.
https://astroaficion.com/2020/10/07/roscas-en-astronomia/
« Últ. modif.: Jue, 31-Dic-2020, UTC 23h.07m. por Toni Tobaga » En línea
villamany
39  Masculino  Cadiz
desde: dic, 2016
« respuesta #10 del : Sáb, 02-Ene-2021, UTC 10h.41m. »
Yo lo hice con un MAK127, no se si tu rosca es la misma.
Echale un ojo, quizas te ayude: Mejorando mi MAK127, visual back y diagonal de 2"
SW Mak127 con dieléctrica 2"
Synscan AZ GoTo con Bluetooth. Sobre trípode EQ5 y trípode de mesa adicional
Oculares 1.25": 6, 10, 12, 15, 20, 25, 32mm. Oculares 2": 26, 30, 42, 50mm
Balow 2x y filtros GSO
RisingCam IMX224
 (Leído 6679 veces)
55
Página creada en 0.275 segundos con 41 queries.
