Tio_Alex
Flaming Star Nebula (IC405)
: Mar, 29 Nov 2016, 12:51 UTC »
Este es mi primera toma con el nuevo GSO RC8 Carbon.
Le falta ajustar el colimado claramente, tiene muy poca integración (no llega a 3 horas)... pero es la primera
Imaging telescope or lens: GSO RC8 Carbon Fiber
Imaging camera: ZWO ASI1600MM-Cool
Mount: Skywatcher AZ EQ-6 GT
Guiding telescope or lens: Teleskop Service TS Optics 80 mm Guide Scope
Guiding camera: ZWO ASI120MC
Focal reducer: Astro-Physics CCDT67 - 0.67x Reducer
Software: Main Sequence Software Seqence Generator Pro, Pleiades Astrophoto PixInsight
Filters: Baader Planetarium SII 1.25" 8nm, Baader Planetarium OIII 1.25" 8.5nm, Baader Planetarium Ha 1.25" 7nm
Accessory: Baader Planetarium Steeltrack 2"
Resolution: 4196x3288
Dates: Nov. 24, 2016
Frames:
Baader Planetarium Ha 1.25" 7nm: 22x300" (gain: 139.00) -20C bin 1x1
Baader Planetarium OIII 1.25" 8.5nm: 4x300" (gain: 139.00) -20C bin 1x1
Baader Planetarium SII 1.25" 8nm: 9x300" (gain: 139.00) -20C bin 1x1
Integration: 2.9 hours
Avg. Moon age: 24.60 days
Avg. Moon phase: 25.09%
Astrometry.net job: 1343606
RA center: 79.143 degrees
DEC center: 34.381 degrees
Pixel scale: 0.699 arcsec/pixel
Orientation: -91.587 degrees
Field radius: 0.517 degrees
Se puede ver aquí:
https://www.astrobin.com/273322
EDITADO: UPDATE 12/12/2016
Bueno, he podido añadir algunas tomas más, corregir el astigmatismo que tenía
y nuevo procesado.....
Technical card
Filters: Baader Planetarium Ha 1.25" 7nm, Baader Planetarium SII 1.25" 8nm, Baader Planetarium OIII 1.25" 8.5nm
Resolution: 4124x3140
Dates: Nov. 24, 2016, Dec. 11, 2016
Frames:
Baader Planetarium Ha 1.25" 7nm: 42x300" (gain: 139.00) -20C bin 1x1
Baader Planetarium OIII 1.25" 8.5nm: 9x300" (gain: 139.00) -20C bin 1x1
Baader Planetarium SII 1.25" 8nm: 15x300" (gain: 139.00) -20C bin 1x1
Integration: 5.5 hours
Avg. Moon age: 17.95 days
Avg. Moon phase: 56.06%
Astrometry.net job: 1370326
RA center: 79.115 degrees
DEC center: 34.385 degrees
Pixel scale: 0.688 arcsec/pixel
Orientation: 89.709 degrees
Field radius: 0.495 degrees
Se puede ver aquí
« Últ. modif.: Vie, 16 Dic 2016, 10:29 UTC por carballada »
re.: Flaming Star Nebula (IC405)
: Mar, 29 Nov 2016, 13:16 UTC »
Tal vez demasiada focal para este objeto no?
Pero bueno es una toma de contacto con el tubo y el resultado es prometedor
Ojo falta un 2 en el enlace a astrobin y te manda a otra foto
: Mar, 29 Nov 2016, 17:54 UTC »
Esta pero que muy bien, el enlace de Astrobin me mando a otra foto, pero le añadí un 2, y he conseguido verla, no se si el defecto que se ve es del colimado, en la foto a resolución completa haciendo zoom se ven las estrellas como triangulitos, y se aprecia en las que están en el exterior un poco de viñeteo, pero para apreciar eso, hay que coger la de resolución completa y acercarse mucho si no, no se nota.
Felicidades menuda foto.
: Mar, 29 Nov 2016, 20:29 UTC »
Cita de: Bufot en Mar, 29 Nov 2016, 13:16 UTC
gracias por avisar, ya he puesto el 2
si, si, demasiada focal, y eso que usé el reductor CCDT67 y disparé a f5,5 y 1100mm... pero no es la mejor elección como objeto, es verdad, era más el probar que otra cosa
: Mar, 29 Nov 2016, 20:51 UTC »
Cita de: Sirio B en Mar, 29 Nov 2016, 17:54 UTC
si, si, falta el 2, ahora ya está cambiado el link
las estrellas están fatal... he realizado una tirada de pruebas después de un primer intento de colimado y algo mejoró, creo que ya no es solamente colimado
este es el canal rojo de NGC891 (ojo a f8 1603mm, tirado a 0.489 arcsec/pixel, claramente oversampled
y el seeing era un desastre, el guiado estaba bien y la expo a 90s)
En realidad que me de una resolución de 0.489 arcsec/pixel me dice que está hecha a 1603mm. Eso me indica que son unos 20,3 mm menos de la focal correcta y por tanto creo que quiere decir que tengo que mover el primario hacia el secundario unos dos milímetros y acercarlo... veremos si mejor despues de esta operaciòn
ya contaré
« Últ. modif.: Jue, 01 Dic 2016, 11:15 UTC por carballada »
: Mar, 29 Nov 2016, 21:59 UTC »
No!
Antes de tocar primario y secundario... ¿no será la distancia entre la cámara y el reductor?
Ese reductor está diseñado para dar x0.67 colocado a 85mm desde el borde de la lente hasta el sensor (x0.75 si lo colocas a 0.50mm del sensor)
Tiene pinta de que has colocado el sensor demasiado cerca del reductor
EDITO: Vale, leyendolo dos veces veo que hablas de la colimación sin el reductor! Disculpa
« Últ. modif.: Mar, 29 Nov 2016, 22:02 UTC por Bufot »
: Mar, 29 Nov 2016, 22:02 UTC »
Cita de: Bufot en Mar, 29 Nov 2016, 21:59 UTC
No!
no, no, todas las pruebas las hago sin reductor para no distorsionar las mediciones, están a f8 directamente, luego ya me pelearé con el reductor
mi idea es seguir tocando secundario, y el colimado del enfocador, el primario no pienso tocarlo de momento
: Mar, 29 Nov 2016, 22:03 UTC »
jajja, @Bufot, nos hemos cruzado
las pruebas que hice con el reductor me daban una reducción de 0,7 (la foto de IC405 de este post) y aún así no se salvaba mucho...
« Últ. modif.: Mar, 29 Nov 2016, 22:06 UTC por carballada »
: Mar, 29 Nov 2016, 22:17 UTC »
¿Tienes el accesorio para colimar el enfocador?
En ese tubo si no me equivoco primario y enfocador van solidarios a la hora de colimar, si no interpones el anillo ese colimador
Supongo que ya tendrás las instrucciones de colimación pero por si no las tuvieras, aquí te dejo el enlace:
https://www.astronomics.com/documents/astro%20tech/astro-tech%20at8rc%20manual.pdf
: Mar, 29 Nov 2016, 22:29 UTC »
Cita de: Bufot en Mar, 29 Nov 2016, 22:17 UTC
muchas gracias, esa pieza la estoy esperando, no pensaba que me hiciera falta al comprar el RC8 la semana pasada, pero creo que es indispensable, también me he conseguido un Howie Glatter (imagino que también lo conoces
) para afinar un poco más... este finde espero pasar el autofoco del SCT al RC y no pasar tanto frío, jajajaja (ya tengo preparada la pletina, los tornillos y el acoplador de 6mm a 8mm)
: Mié, 30 Nov 2016, 01:04 UTC »
solo puedo decir que me encanta.
A ver si algun dia logro una foto adi.
: Mié, 30 Nov 2016, 11:40 UTC »
Cita de: ReneTenerife en Mié, 30 Nov 2016, 01:04 UTC
muchas gracias @ReneTenerife
No es nada y no está tan bien, estoy aprendiendo y aún me falta mucho, pero en mi opinión sí que hay una buena dosis de aprendizaje, búsqueda y tal y tal, pero una buena parte del éxito se debe al presupuesto... no nos engañemos
Ojo, creo que es cierto que cada año que pasa es necesario menos presupuesto para obtener mejores tomas y que llegado a un nivel las diferencias son mínimas
: Mié, 30 Nov 2016, 13:45 UTC »
Cita de: carballada en Mié, 30 Nov 2016, 11:40 UTC
La dosis de presupuesto........si dimelo a mi que estoy desde 1 año y medio ahorando y ahorando y poco a poco aumentando mi equipo, lo mas caro ya esta pero un euro ahi un euro alla.......
un saludo
: Lun, 12 Dic 2016, 14:42 UTC »
Technical card
Frames:
Se puede ver aquí
« Últ. modif.: Vie, 16 Dic 2016, 10:30 UTC por carballada »
: Lun, 12 Dic 2016, 18:26 UTC »
Yo la veo espectacular.
: Lun, 12 Dic 2016, 20:14 UTC »
Cita de: Sirio B en Lun, 12 Dic 2016, 18:26 UTC
muchas gracias
: Vie, 16 Dic 2016, 10:30 UTC »
he vuelto a recuperar las imágenes que no se visualizaban...
Tema leído 8702 veces
