Unimap, soft para identificación de objetos en las fotos
GonZoo
46  Ibi, Alicante
desde: ago, 2009
« : Jue, 20 Ene 2011, 13:21 UTC »
No se si conocéis este software: Unimap. Está todavía en desarrollo (vamos, está en alpha) pero funcionan ya muchas cosas.
https://larryo.org/work/information/unimap/index.html
Tiene bastantes funciones pero la que más me ha impresionado es esta: transformar esto
en esto
La lista completa de funciones es impresionante
IMAGE DETECTION/ANALYSIS/PROCESSING
  • automatic detection of stars using several catalogs: SAO, HIPPARCOS, TYCHO-2, USNO B1.0, NOMAD, 2MASS, GSC
  • automatic image mapping of DSO by Messier, NGC/IC, HYPERLEDA, UGC, MGC
  • automatic mapping of radio sources, xray/gamma sources, supernovas, extra-solar planets,
  • asteroids, comets and artificial earth satellites
  • on click details (catalog info, measurements, spectrum, note and citations) for detected stars and galaxies. Data is mostly fetched from online source like Centre de Données astronomiques de Strasbourg, United States Naval Observatory Flagstaff Station , Centre de Recherche Astrophysique de Lyon, The Extrasolar Planets Encyclopaedia, NASA Orbital Information, NED - NASA/IPAC Extragalactic Database .. etc.
  • access to imaging from various surveys(DSS, etc)
  • draw constellations lines+artwork for several cultures( Western, Chinese, Norse, Navajo, etc)
in image object/source search tool
  • Astronomical Distances Measurement Tool - measure distances in the sky between stars and galaxies
  • equatorial grid overlay
  • 2D image distortion grid (test)
  • 3D image distortion
  • 3D image color graph
  • image processing(color/filters)
  • Image tagging with automatic EXIF data extraction(if available), position, target details, equipment used, weather conditions and text/record audio notes
  • Can open/save images in any of the formats: FITS, JPEG, TGA, BMP, GIF, TGA, TIFF, PSD, and a number of raw formats from digital cameras such as Canon, Nikon, Pentax, FujiFilm, Minolta, Olympus.
  • can print images with or without annotations
  • can upload/download/browse images and analysis data associated to an online collaboration site
customize the appearance (objects marks/units/lines/paths/etc)[/list]
IMAGE SEQUENCE ANALYSIS/PROCESSING
  • Image registration/stacking
  • automatic discovery of unknown objects
  • automatic path discovery of moving objects (test)
  • group info tagging
INSTRUMENTS CONTROL PANEL
  • works with multiple cameras simultaneous
  • most digital and web cameras are supported however only Canon Eos is fully implemented as per their SDK.
  • telescope and focus control. Does goto to any of the available catalog targets, tracking, and guiding. It works with ascom as well as a full implementation of the communication specification for meade and Celestron
  • realtime graphs: image histogram, weather conditions and focus
OTHER TOOLS
  • Observer profile: location(manually,geoip,gps), hardware setup, sites
  • Environment/weather monitoring tools: satellite imaging, forecast, seeing, light pollution map.
  • World Wide Astronomical Observatories Interactive Map with photos and details
  • Latest Sun image from SOHO and also XRay and last B-Field Event
  • Latest news headlines browser and calendar of ESA and NASA events
  • Planner - basic tasks/observation logs
  • Various calculators - instruments focal length, field of view, iso, units conversion etc.
55  El Prat de Llobregat
desde: may, 2010
« respuesta #1 : Jue, 20 Ene 2011, 14:27 UTC »
Parece interesante, voy a echarle un vistazo.
Aprendiendo...
« respuesta #2 : Jue, 20 Ene 2011, 17:53 UTC »
Si que parece interesante si, por probarlo no se pierde nada.... OKOK
desde: may, 2010
« respuesta #3 : Jue, 20 Ene 2011, 20:11 UTC »
A mi no me funciona. Lo he probado con las dos versiones y no hay manera, no se llega ni a abrir. Esperaremos a una versión más pulida.
GonZoo
46  Ibi, Alicante
desde: ago, 2009
« respuesta #4 : Jue, 20 Ene 2011, 20:35 UTC »
curioso, a mi en linux con wine (un soft que permite ejecutar algunos programas de windows) me funciona
desde: may, 2010
« respuesta #5 : Jue, 20 Ene 2011, 20:51 UTC »
Yo en realidad lo estoy usando con Parallels, un soft que virtualiza windows en OS X.
Aprendiendo...
« respuesta #6 : Jue, 20 Ene 2011, 22:18 UTC »
Pues yo tengo Win7 y tampoco me funcionan ninguna de las dos versiones, en ambas me deja iniciar el programa y abrir alguna imagen pero en cuanto le pides que realice alguna funcion me salen errores y he de cerrarlo. Triste
larrylart
« respuesta #7 : Vie, 21 Ene 2011, 00:00 UTC »
Hi,
Can you please email me the image you have been having problems with? For the past few months I haven't had the time to work much on the project as I had to move jobs and house but from next month on I will be working to fix a series of problems/bugs I have received so far and if this is the case I will fix it as well.
Thanks and please feedback even in spanish I will use online translation tools and if you give me a images with problems and maybe a screenshot or two will do
Larry
Hi Larry !
I'm the admin of the site, and I confused you with a spammer and removed you from database user of forum,  SORRY
aaaiii
please,
if you interested, re-register yourself in a forum
SORRY !
.admin.
GonZoo
46  Ibi, Alicante
desde: ago, 2009
« respuesta #8 : Sáb, 22 Ene 2011, 14:05 UTC »
Admin, ¿qué manera es esa de tratar a los invitados? Cheesy
Please Larry come again, this forum has its doors open for you.
desde: may, 2010
« respuesta #9 : Sáb, 22 Ene 2011, 20:48 UTC »
Ostia admin te has cargado al que nos tiene que arreglar el software. Es que ya con tanto viagra y "alargapenes" cuando uno ve un nombre inglés se le va el dedo al delete, eh. Sonreir
« respuesta #10 : Sáb, 22 Ene 2011, 23:18 UTC »
Hi,
Larry
¿Podéis enviarme un correo con la imagen que os está dando problemas? Los últimos meses no he tenido tiempo para trabajar en el proyecto ya que he cambiado de empleo y domicilio pero para el próximo mes voy a solventar una serie de problemas/bugs que he recibido y si éste es el caso lo solucionaré también.
Gracias y por favor opinad incluso en español, usaré herramientas de traducción y si me enviáis imágenes con problemas, o una o dos capturas de pantalla lo haré
Larry
Traduzco a mi manera para los que se pelean con el inglés (y para que no tengáis que tirar de traductor online) OKOK
Si le respondéis en castellano ya intentaremos traducírselo desde aquí para que no tenga que andar haciéndolo él  Giñar
« respuesta #11 : Lun, 24 Ene 2011, 01:20 UTC »
que vergüenza
fuí más rápido borrando que pensando
( me pareció que como algún tipo de spammer que existe, hablando ambiguamente sin citar nada en concreto, y lo típico que no puede contestar etc. ..  en fin  que ...  es lo que pasa ...)
Tema leído 8721 veces
